7004r .300 Intermediate-Reverse boost valve Question
Old Jan 19, 2018 | 07:39 AM
riche's Avatar
Car: 1969 C-10 Truck
Engine: 355 Small Block, HSR, HP EFI ECM
Transmission: 700 R4
Axle/Gears: 373
Im building a trans with a transgo shift kit, I have a .500 valve and corvette servo. But I didn't get .300 valve.
It's a 92 700r4 trans and it has a .283 (.282 measured) valve in it.
That is bigger than the min valve the instructions call for, but I see the .300 valves out there and it isn't that much to get one.
I am sure I would be fine with the one I have, But do I need to go ahead and pick up a .300?
And just so we are clear, I do not care if this transmission snatches the filling out of my teeth when it shifts.
It is for my play toy, I have a daily driver for smooth shifting.
Old Jan 21, 2018 | 06:57 AM
Pro Built Automatics's Avatar
Re: 7004r .300 Intermediate-Reverse boost valve Question
The .300" intermediate/reverse boost valve will give firmer 1-2 manual shifts, and higher line pressure for reverse. The .296" intermediate/reverse boost valve is much cheaper, and is close in line pressure. How much horsepower here? Do you manually shift the transmission? Or leave it in Drive for going WOT?
Old Jan 21, 2018 | 08:06 AM
riche's Avatar
Axle/Gears: 373
Thanks for the reply, I will be under 400 up and manual shift all the time. (Have ratchet shifter)
chevysquid
Jan 18, 2011 12:08 AM
tpi_roc
Apr 1, 2002 06:38 PM
