only shifts into 2 4 6 gears
So i have a 2002 WS6 with T-56. Driving one day and downshifted to 3rd and gas it a little hard and shifted to 4th and let up. Went to down shift and found it could not get 1 3 5 R, very sloppy. I will get 2 4 6. It is not the shift stops because it will let shifter go all the way and touch surrounding console
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: only shifts into 2 4 6 gears
Shifter stops out of adjustment
https://youtu.be/-5JBIyG-Sn8
If not those something is internally busted time to pull and check it out. Or at least pull the shifter and look
Well I thought shift stops from reading other post, will only allow the shifter to move a short limited amount of travel and not let it engauge. My shifter is allow to go full range until the console stops it. Very slushy or sloppy. I also played around with it last night and now it won't go into 2 4 6 either. Well not consistently. Now when i do manage to get it to go into 1 3 5 R it drives fine!!!!!!!!!!!
BHR
Sep 25, 2017 06:58 PM
Dartht33bagger
May 1, 2017 10:24 PM
