T-5 swap gone bad
Old 05-25-2018, 10:17 PM
  #51
NoEmissions84TA's Avatar
Re: T-5 swap gone bad
Originally Posted by Ty92Z
Just some reference pics. Top flywheel is GM 14088847 removed from my all original 92 Z28. Bottom is GM 14088671 from a T5 swapped L98. Top flywheel is much lighter.
Nobody noticed that batwing weight on the top flywheel?
Edit: batwing usually refers to the weight on the flexplates.
Old 05-25-2018, 10:54 PM
  #52
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Yes, the weight is on both flywheels directly across from the locating hole. It’s more obscure on the bottom flywheel because of the rust.
Old 05-26-2018, 12:18 AM
  #53
OH. Sorry, obscure is right, I can't see it.
Old 05-26-2018, 01:57 AM
  #54
Twin_Turbo's Avatar
And as you can see both are counterweighted
Old 05-26-2018, 04:19 AM
  #55
86Z
86Z's Avatar
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Both are for 1pc rms, so I believe either would be correct. TPI cars got the lighter flywheel and the TBI cars got heavier piece. Performance wise I would think one would prefer the lighter flywheel. I have a flywheel from an 2wd 87 Chevy truck that came with a 1pc rms sbc and a 4 speed. I will dig it out tomorrow and see if/how it’s different.
just my opinion on this....
i changed to the lighter flywheel on a clutch swap when i was running a cammed 305 and i did not like it.. no momentum on take off. went back to the heavy one
Old 05-26-2018, 08:35 AM
  #56
Ty92Z's Avatar
Engine: LB9 LO3
Maybe this angle helps NoEmission84TA.
Old 05-26-2018, 08:39 AM
  #57
Ty92Z's Avatar
Engine: LB9 LO3
This is the 168t flywheel from my truck, also a 1pc rms sbc.
Old 05-26-2018, 05:57 PM
  #58
Yes, now it's clear.
Old 05-26-2018, 06:10 PM
  #59
Originally Posted by 86Z
this is a stock replacement flywheel that i bought for my original t5 1986 over 10 years ago.
So to clarify, this is the flywheel heavyduty needs, correct? p/n 14088671 N
The one with the small counterweight that compensates for the change in the crank flange from 2 pc to 1 pc.
post #37 https://www.thirdgen.org/forums/tran...ml#post6224367
Old 05-27-2018, 09:23 AM
  #60
86Z
86Z's Avatar
Car: 1986 Camaro SC
yes, heavyduty need 14088671
Old 06-29-2018, 08:43 PM
  #61
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
Axle/Gears: 4th gen with 342's
****UPDATE**** so the vibration problem has been solved.... It was a simple fix. The one piece RMS 5.0 takes a NEUTRAL balanced flywheel... Dont care if the flex plate has the butterfly weight on it... Finally had the chance to swap out the standard balanced for the neutral balanced and reused all the hardware and NO balance... Im thinking the information on this subject should be updated so others dont run into this issue. Thanks to everyone that offered advice on the subject it was much appreciated.
Old 06-29-2018, 10:25 PM
  #62
Glad you solved it.
Do a burnout to celebrate.
matts86cam
02-05-2012 12:54 PM
louiethebats
07-06-2009 07:06 PM
Nefarious
06-12-2007 11:50 PM
SeanTimothy
11-20-2003 09:54 PM
Berlyn0963
02-06-2002 03:37 PM
Quick Reply: T-5 swap gone bad
