TV cable replacement
Old Jan 6, 2002 | 03:44 PM
Berlinetta's Avatar
I know how to adjust the TV cable, but what i want to know is how do i replace it. Thanks a lot!!
85 Berlinetta 2.8, Auto
91 RS 5.0 TBI, Auto, 80 series Flowmaster w/ chrome tips, Open element air cleaner w/ K&N <------Building her up for the sole purpose of being able to whoop a** on every 5.0 Mustang out there. Just dont have the money yet.
Old Jan 7, 2002 | 04:25 AM
transfixleo's Avatar
First disconnect the cable at the throttle body. Now pop the casing out of the bracket. Put the car safely on stands and take the 10 MM bolt out that holds the cable into the tranny and with a catch can under the tranny pull the cable up out of the tranny. After the oil gushes out, disconnect the actual cable from the link inside of the tranny. Reverse the procedures to reinstall.
To adjust the TV Cable skip the book method and do this: Press the 'D' shaped lock button on the adjuster and loosen the cable setting (The black housing that the metal cable is in will move forward). Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the 'D' button and pull the cable casing (the black tube) back as hard as you can (putting maximum tension on the metal cable) and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable casing so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old Jan 7, 2002 | 02:46 PM
Berlinetta's Avatar
Thanks a bunch man
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
