1983 firebird belhousing issue
Old Jul 3, 2018 | 05:10 PM
lgunderson's Avatar
I am rebuilding a 1983 firebird F body. It came with a stick shift and a 6 cyclender engine.
18 years ago I put a GM 350 and an automatic tranny. I just had the engin rebuilt and am switching it back to a stick. I have a T5 borgwarner transmission, poss rearend and bell housing from a 1992 Iroc. When I bolt everting up the transmition sits on a slant. I have a bell housing that makes the T5 sit straight but it is not set up for a Hyd clutch. Can I hook this transmition with a manual clutch is so what do I need. The bell housing that works just has a hole in the side for the fork? Any help would be appreciated. This is my first post so if I didn’t do this correct I apologize in advance.
Old Jul 3, 2018 | 05:13 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: 1983 firebird belhousing issue
???? How much of a slant?
Old Jul 3, 2018 | 05:27 PM
The correct BH for these cars rotates the trans about 18 degrees toward the driver.
Sounds perfectly normal to me.
Old Jul 3, 2018 | 05:30 PM
lgunderson's Avatar
About 15 degrees.
Old Jul 3, 2018 | 06:16 PM
lgunderson's Avatar
Thank you very much, will the oil will still cover the gears ok? Do have a suggestion on where to get a new slave cyclender and the linkage. All I have is the pedal coming through the floor.
Old Jul 3, 2018 | 07:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The splash lubrication in the third gen T5 application works fine, ( I have done sustained 140mph) but that is an excellent question.
The answer to your questions is mostly "Parts from an 84-92."
The V6 and V8 models in 84 got a pedal stud added for the 84-92 master cylinder.
Pedals for an 84-87(?) should have the same neutral lockout switch. Everything else from your car should bolt up to an an 88-92 pedals.
The crossmember for an 83-92 will fit your car ( but not an 82)
Happy shifting.
Old Jul 3, 2018 | 08:26 PM
Yup, looks completely usual and customary.
Observe that the trans mount flange is exactly horizontal and the shifter exactly vertical.
You need 84-92 pedals and hydraulics. As noted, earlier pedals are an easier fit. Hydraulics are all interchangeable and I think still available new.
TVP122
Apr 7, 2014 02:04 PM
mrogers
Jan 23, 2011 04:12 PM
Toyota h8r
Mar 11, 2007 11:51 PM
