Speedometer for T56
Old Jul 20, 2018 | 09:15 AM
ponzia's Avatar
Car: 1986 Firebird Trans Am
Engine: 383 Stroker
Transmission: 1996 T56
Axle/Gears: Stock 3.26
Speedometer for T56
I have converted my Trans Am from a manual T5 to a Pontiac Firebird 1996 T56. both trans use an electronic speedometer. How can I not get the stock speedometer to work?
Old Jul 20, 2018 | 09:38 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Speedometer for T56
You need to wire in a new buffer box. Do a search here there are some threads on it.
Old Jul 20, 2018 | 01:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Dakota digital sgi-5e
https://www.summitracing.com/parts/d...SABEgKrvPD_BwE
Old Jul 20, 2018 | 09:24 PM
Yup. Buffer box.
Gotta get from 17 pulses per rev of the drive shaft coming from the transmission, to 2 going into the speedo. Not too tough really, kinda a no-brainer actually. Those electronic adapter boxes will fix you right up.
Old Jul 21, 2018 | 10:29 AM
Twin_Turbo's Avatar
You calculate pulses per rev to ppm depending on axle ratio and tire size. Tgen figure out what you need to get a 4k ppm signal. I have used the stock buffer box to get down from a converted 8k ppm. Just use the input and tgen pull vss off the 2k cruise output.
Old Jul 23, 2018 | 07:32 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 86 Firebird has the 4004 pulse per mile VSS signal at the transmission split and converted (to 2002 ppm cruise, 4004 speedometer, 2002 ECM) by a buffer box. So you only need a single converter circuit device to reduce the trans. signal to your stock buffer box. The SGI-5E works, but a simpler device will too.
Old Jul 23, 2018 | 08:16 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have an SGI5 box and I am in NJ if you want to buy it from me
rarebmx
Apr 14, 2015 06:27 PM
REVLIMIT
Nov 2, 2002 10:10 PM
mach158
Jun 28, 2002 08:30 AM
ssbowtie1
Jan 29, 2002 07:23 AM
lock
Jan 1, 2001 07:58 PM
