9” brake options
Old Aug 12, 2018 | 08:03 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
9” brake options
I’m going to order a 9” housing from quick performance and I’m not sure what to order for brakes. I have the 9bolt with disk brakes currently and would like to keep rear disks but I run 15 inch wheels for the track so I have to be careful of the size of the brakes. Will the 93-97 Camaro brakes fit inside of a 15” wheel? I believe they are slightly smaller than the later ls style brakes. I didn’t see an option to adapt the stock disks to the 9”.
Old Aug 12, 2018 | 09:49 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: 9” brake options
You have allot of options but pick your brakes before ordering your rear axle. Do you want a parking brake? You can bolt on 98-02 fbody rear brakes but you will need to grind the calipers to clear some wheels. Otherwise you can go with a willwood setup. I guess what are your plans for the car?
Old Aug 13, 2018 | 06:48 AM
big gear head's Avatar
The Ford Explorer brakes are a popular option for the 9 inch. You can get them with or without the parking brake. QP can help you with your decision.
Old Aug 13, 2018 | 07:30 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I run factory 89 PBR brakes on my moser 9" with my 15" welds for the track. It's close but works. Some have had to grind a bit off the caliper fin area to work.
Old Aug 20, 2018 | 06:43 PM
ransam's Avatar
Did you use the factory bracket or did you fabricate one?
Old Aug 20, 2018 | 08:33 PM
TTOP350's Avatar
Me? I used the factory 89 brackets. Had to drill some holes but no big deal.
J0hn_J0hn08
Mar 16, 2015 07:59 PM
Veaceonee
Jan 19, 2013 10:19 PM
86irocterror
Brakes
Aug 29, 2006 05:07 PM
jcb999
Nov 21, 2002 09:29 AM
