86 camaro fuel pump
Old Oct 2, 2018 | 07:15 PM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
86 camaro fuel pump
IveI got a 86 camaro v8
It has some starting /staying on problems... I think itsi the fuel pump. If not then maybe the carberator....
I need to replace my fuel pump and fuel filter. However I don't know what kind to get...
Can someone please tell me what type or kind to get?
Also Is it an electronic fuel pump?
Old Oct 2, 2018 | 07:42 PM
skinny z's Avatar
Re: 86 camaro fuel pump
Need a little more info here.
Old Oct 2, 2018 | 09:09 PM
Engine: 383 Stoker
How about now
Old Oct 3, 2018 | 12:40 PM
skinny z's Avatar
Year. Model. Engine. VIN.
There are possibly a half dozen options depending on what you own.
Old Oct 4, 2018 | 01:00 PM
skinny z's Avatar
Did you find your answer?
Old Oct 6, 2018 | 07:08 PM
Engine: 383 Stoker
No unfortunately
Old Nov 9, 2018 | 06:25 PM
Grandpa's Avatar
Car: 1990 Camaro RS 3.1L
Engine: 3.1L v-6
Transmission: 200R4
Chelseahere If you have an 86 v-8 with a carb you have a mechanical fuel pump should be on the passenger side of the engine at the front. It only has two bolts that hold it on. As for which kind any good brand from the parts store will work unless you have a built engine that needs more pressure. I hope this helps oh and when you change the pump change the filter also should be right beside it.
kowboy59
Nov 7, 2011 09:36 PM
Twilightoptics
Nov 18, 2002 01:26 PM
BuckeyeROC
Apr 29, 2002 07:18 PM
makinemtap
Jan 30, 2002 01:09 AM
442guy
Apr 13, 2001 04:58 PM
