REplace C clip axles damaged
Old Oct 16, 2018 | 06:38 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
I have an 82 camaro 10 bolt,,Borg Warner diff with 26 spline axles.
Eaton tru Trac fuitted car goes good,,
Diff guy reported one axle slightly bent,, another one has damage from wheel bearing failure...
i need to replace both axles with another set no problem
Can i do this at home with car jacked up or does this require a hoist and special tools to remove c clips from the centre to get axles out..
and can the job be performed with relative ease or do i pay the diff guy to do it in his shop and pay him....
Old Oct 16, 2018 | 06:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: REplace C clip axles damaged
The following will provide some answers:
https://www.thirdgen.org/forums/tran...ing-axles.html
About axles, check the link below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Oct 16, 2018 | 09:01 PM
big gear head's Avatar
The Borg Warner rear end does not have c clip axles. The GM 7.5 10 bolt does have c clip axles. You can replace the axles easily with a jack and jack stands. You will also need to replace the axle bearings and seals. When you remove the cross shaft to get the c clips off DO NOT TURN THE AXLES OR THE DIFFERENTIAL. If you do then the gears are going to get out of alignment and possibly fall out. Remove the c clips and put the cross shaft back in place while you are doing the other work. Then remove the shaft again when putting the c clips back on.
JohnnyRS
Sep 12, 2012 11:29 AM
grove
Apr 15, 2008 08:31 PM
94-6spd
Dec 8, 2002 05:51 PM
TomP
Mar 11, 2002 01:38 PM
