454 with 700r4
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
454 with 700r4
Is there a factory application for a 454 with a 700R4? I checked on Rock Auto for a few years and the ones I looked at were all TH400 or 4L80s. My friend said my TH400 flexplate would work, but once I got it bolted up, should have checked first, the torque converter wouldn't line up with either set of holes. I know I can get a flexplate from Summit or something, but I was hoping to get one really cheap from a factory application. This whole deal was supposed to get me OD cheap since I only paid $50 for the trans, I know it's good and I didn't want to spend much more money on this project. I am already bleeding money for other crap I thought was going to work. Sometimes parts you have lying around aren't the best way to go, lol
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: 454 with 700r4
Apparently some 80's c20 trucks supposed to have had an option for a 700r4, but with 350. Does the 400 use the 168 tooth felx plate?
Car: 92 Firebird
Engine: 4.8 LR4
Re: 454 with 700r4
I guess I could also ask, what is the bolt diameter for the 700R4 torque converter? It's a stock TC from an 84 Trans Am
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 454 with 700r4
IIRC the 1987 V20 Suburban came with a 700R4 and 454
Car: 92 Firebird
Engine: 4.8 LR4
Re: 454 with 700r4
Thanks for the reply. Rock shows the same two flexplates for basically ALL the 454's from the 70s to the end of the 80s regardless of the model.
It looks like Summit has a brand one for $30 and an SFI for $55, both with the dual converter bolt pattern. I think I'll just grab one of those.
Re: 454 with 700r4
Easy fix, drill new holes, or slot the existing ones. Did this many a time in the past. Remember the torque converter stays in alignment with the transmission from the torque converter snout going in the back of the crankshaft, not the bolt holes.
Car: 92 Firebird
Engine: 4.8 LR4
Re: 454 with 700r4
Eventually I will need two flexplates anyway, so I am just going to buy one. I don't like opening up holes, regardless if the snout is doing the work.
Car: 92 Firebird
Engine: 4.8 LR4
Re: 454 with 700r4
It's never straight when I try to make holes like that, hence the "I don't like opening up holes" lol
UnderCover89TBI
36
May 24, 2014 01:34 PM
Jake88maro
Theoretical and Street Racing
Mar 14, 2011 11:57 PM
