10 bolt torque arm differences?
Old Oct 26, 2018 | 04:21 PM
Fiero388500's Avatar
Car: 1985 Camaro + 2000 Honda Prelude
Engine: 2.8 v6
I haven't found much about this, maybe someone here knows. I have a 1985 v6 camaro with a 700r4 and I had to get a rear axle recently. I purchased one off an 82 camaro and after some minor reconditioning I installed it. Everything bolted up with no issues whatsoever, EXCEPT, I didn't bother checking if the torque arm mounts were the same as I haven't seen anything that would mention any differences in them except at the trans. Well, the mounts on the 82 axle are shorter than the ones on the 85 and I needed to use about 1in. worth of spacers on both sides of the mounting bolts to get it to fit somewhat properly. It's in, but not properly and will loosen up from time to time. To be clear, both are 10 bolt 7.5 axles with 3.42 gearing and are virtually identical except for this one difference. The 85 axle is the same axle that has been on the car for its entire life and the torque arm fits it perfectly and is not stretched. My question is, were there 2 different torque arms? If so, can anyone direct me to a stock application that will work for the smaller of the 2, or am I just missing something? The axle with the shocks in the pic is the 85.
Old Nov 2, 2018 | 02:21 PM
Mr.Gordon's Avatar
From: East coast, northern. Gonna head to Fla. soon, retirement .
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: 10 bolt torque arm differences?
Swap the carrier and axles into your old banjo.
Old Nov 24, 2018 | 11:48 AM
Mr.Gordon's Avatar
Plus1 on swapping everything into your old housing. It should be a easy swap as the parts are all the same.
Either that or spend $300 plus for an adjustable torque arm. But then you need a crossmember and all to get it all lined up properley.
Old Dec 16, 2018 | 02:36 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
I was kinda in the same boat. I went from a '88 rear to a '85 and the t/a was different. They bolt up fine but the bushings were different in the mount. I guess I got lucky.
Old Feb 3, 2019 | 10:03 PM
Engine: 2.8 v6
Update. The 1982 camaro came with a th350 transmission option which requires a longer torque arm and the design is different from ALL the other years. This is the only year it came with a different rear axle and the arm is too long to fit the 700r4 without major modification or hack, measure, and weld. Hope this helps anyone in the same pickle.
Old Feb 4, 2019 | 07:21 AM
The 82 did NOT come with a Turbo 350. It came with a 200C. No T-350 ever came in a car with a torque arm. The 200C is pretty much the same external dimensions as a short-tail 350 however, making the 350 an EXTREMELY popular swap, back in the day. If the car your parts came from had a 350 in it, then it had been swapped.
But yes you are right: the TA is quite a bit different in a 200C car than a 700-R4 or T-5 one. The axle housing AFAIK is the same, only the arm is different.
There's a casting # on the pumpkin. Compare the 2 that you have and see if they're the same.
Not sure if there's a year-model difference in TAs about requiring the spacer at the axle or not. My 83 has one. It's just not something I've ever paid much attention to in other cars.
Old Feb 4, 2019 | 08:09 AM
Engine: 2.8 v6
Gotcha, that's just what I was told by a 3rd gen parts place in North Carolina. But yes, the 82 rear axle torque arm mount is where my problem lies. I'm thinking I can have a shop weld on the correct size spacers on the axle to fit the torque arm that's on the car now instead of hacking a perfectly good torque arm apart. Also, what was the 200c? I've only heard of the 200r4 and that's supposed to be a differently geared trans compared to the 700r4 (again, so I'm told).
Old Feb 5, 2019 | 02:51 PM
No need for "weld"; just get one off of an early car, like my 83. It goes at the bottom.
The 200C was a little weenie 3-speed w/ lockup POS from the late 70s/early 80s. Notoriously weeeek and flimsy. The 200-4R is not related to it in any manner way shape or form other than the name. I don't think they share any parts at all except maybe pan bolts.
dave mc
Sep 5, 2009 04:28 PM
Pablo
Jun 1, 2004 11:08 PM
vegaken
Dec 4, 2003 08:45 PM
