T5 leak evidence guidance
Old Nov 2, 2018 | 07:39 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
friends!
I have my T5 bolted off of my engine and am casually inspecting it for an idea of life left in it by looking for evidence of case stretch
It's from a V8 TPI 91 car (and the id on the case looks to corroborate with this) which perhaps was once loved, but has I suspect has been whored out in her autumnal years.
Anyway I attach some pics of it freshly removed (apologies to those with stiff necks). I think I know the answer here, but welcome views from seasoned T5 veterans, forensic experts, Colombo-esque burgeoning detectives.
is this an open and shut case of fluid leak under the bearing? I suppose what's giving me false hope is the dirt on the bearing which perhaps suggests it hasn't moved?
Old Nov 3, 2018 | 01:23 PM
Re: T5 leak evidence guidance
That bearing is a relatively loose fit, with an O-ring to seal it, as opposed to the press-fit in the 1st design T-5. Since it hasn't been spinning in the case, the case is probably OK.
I'm not really seeing evidence of any significant leaking.
Old Nov 3, 2018 | 06:41 PM
GTA1990's Avatar
Car: 1991 Trans Am
thank you sir; coming from you I wonder if I should print this and add to the history folder of the car
FLYNLOW92rs
Jul 26, 2004 09:42 PM
jcb999
Jun 24, 2002 08:29 AM
Joel Geerling
May 22, 2002 05:14 PM
Kevin91Z
Dec 13, 2001 09:15 PM
