Need Help Diagnosing Converter Prob.?
Old Jan 8, 2002 | 03:41 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
I just rebuilt my motor a month ago and i pulled the tranny with it. i put in a shift kit while it was out. Since then everytime i put it into reverse it is slipping for a few seconds. Now when I'm at drive throughs the engine is geting bogged down by something every few seconds while idling while making a rattling sound. Ounce it even quit on me but started right back up. Any Ideas?
Old Jan 8, 2002 | 10:45 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Ummm... anybody? somebody has to know about transmissions on here
Old Jan 9, 2002 | 04:07 AM
transfixleo's Avatar
By shift kit, do you mean a genuine TransGo SK or some other VB kit? When a problem appears after doing something, usually retracing your steps will show you a missed step or a mistake made. Is it full of oil? It almost sounds like two different problems. Somehting in the tranny causing the Reverse problem and perhaps an unrelated engine problem causing the other.
Old Jan 10, 2002 | 12:42 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
I used a b&m shift kit that i got form auto zone. I'm pretty sure I did all the steps correctly because i was so nervous about worling on it i tripple checked all my work and i check the fluid regularly and it is usually full. (have a small leak at transmision cooler lines). I went to a tranmission place today and they said the EGR probably had a problem and they were right. I found a hose that is broke. but the reverse problem is still there. thanks for helping me!
84LsxZ28
May 17, 2020 02:21 PM
FormulasOnly
Jul 23, 2018 08:47 AM
2012sergen11
Oct 13, 2015 07:38 PM
okfoz
Oct 13, 2015 02:19 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
