now my car is not shifting?
Old Jan 8, 2002 | 10:37 AM
88_RS&86_Z-28's Avatar
I have a 88 RS and i removed the stock 2.8 and now i have a mean 406 in it and race season is about to start. After i got everthing put back together i drove the car about 1 block and it shifted fine i did not have the TV cable hooked up mine was trashed so i had to wait for a new one to come in. Then i got the new one in and now it wont shift out of 1st? so i unhooked it and it still wont shift out of frist? what in the heck is wrong here?
Old Jan 8, 2002 | 06:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I'll asume you've adjusted the TV cable properly. If indoubt
use Transfixleo's method.
after that i'd look for
Low fluid level ,TV valve may be stuck full in. Governor broken or stuck. I'd bet on the TV valve.
Old Jan 9, 2002 | 07:40 AM
how do i go about getting the TV valve unstuck and just where is the TV valve? sorry but dont know that much about trannys
Old Jan 9, 2002 | 08:25 AM
F-BIRD'88's Avatar
It might be better to get the help of a professional
trans tech to fix your trans. Not rebuild it, but fix the problem.
(Assuming the tranny isn't smoked)
This would involve dropping the trans pan and disissassembling the valve body. The different valves etc need to be inspected and cleaned. This would be a good time to install a "Transgo SHift Kit"
This kit containes certain fixes and cures specific to the th700r4
such as the stuck TV valve. Have him inspect the 2-4 servo for broken parts while he's installing a "corvette servo" also.
Then have him inspect the govenor for wear or a stuck piston.
Have him check proper tv valve, cable carb linkage operation
while the pan is off.
Find a experienced trans tech, tell him the problem and
what you want done. Get him to estimate the job before hand.
If its within your budget, get him to do it and pay him.
If it takes a little longer than planed, and he has to charge you a little more , thats life. But it should be pretty straight forward
and not cost an arm and a leg.
Because of your lack of knowledge on this , I think its your best bet.
You say you just did a motor swap. Where did the trans come from? Junk Yard?, bought used,? took for another car.?
Fresh rebuild?
What is the condition of the trans? Did it ever work right for you?
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
