Engine turns but flywheel does not
Old Dec 11, 2018 | 07:51 PM
Ralphm2425's Avatar
I recently picked up a 1986 z28 with a swapped engine (350 carb). It hasnt been started in years, and when I tried turning it over it seemed like the starter wouldn't fully engage the flywheel. So I tried cranking the engine with a ratchet to see if it would rotate and it turned reasonably easily. However, when i checked the flywheel after I cranked the engine a few more rotations, I noticed it hadn't moved at all. What would cause this??
Old Dec 11, 2018 | 10:34 PM
GeneralDisorder's Avatar
Re: Engine turns but flywheel does not
Broken flywheel bolts, or broken crankshaft.
GD
Old Dec 12, 2018 | 07:00 AM
DEADWOLF's Avatar
Car: 1990 Firebird Drag car build
Engine: 355 being rebuilt
Axle/Gears: 4.56 LDS
GD
Yes and either one of these will require engine removal. Stock cast crank shafts can only hold up to so much power.
elcotony
Dec 2, 2014 09:16 AM
newagereject
Jun 25, 2011 07:01 PM
oamhmad
Nov 8, 2010 08:44 PM
kkingsrulee
Mar 9, 2009 09:25 PM
ScreaminDeamin85Z
Nov 9, 2001 10:14 PM
