Aftermarket 28 Spline Axle Shafts 10 Bolt?
Car: 2002 Camaro SS
Engine: Built LS
Anyone have any suggestions for new axle shafts that fit the 3rd gen rear 10 bolt?
Have a 26 spline car that needs a posi installed so rather just buy a 28 spline and upgrade it all.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Aftermarket 28 Spline Axle Shafts 10 Bolt?
I used a set by Alloy. Good quality, used press in or screw in studs, but didn't work directly with the torsen posi I was using
Car: 2002 Camaro SS
Engine: Built LS
I'll see what I can find under those brands and post them here, if anyone has some links let me know as well.
Car: 2002 Camaro SS
Engine: Built LS
https://www.summitracing.com/parts/a...t/model/camaro This seems to be a nice bet.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I used these on my 26 to 28 spline conversion
https://www.summitracing.com/parts/sum-700118
I had issues with my factory rotors not fitting on the ends I had to have them turned down about 0.3"
z28cam100
Oct 3, 2010 07:13 PM
Sonix
Jan 3, 2008 11:22 AM
327_TPI_77_Maro
May 23, 2007 07:34 AM
Black is Best
May 17, 2007 12:48 PM
IROC-You
Sep 7, 2006 11:19 AM
