Slave cylinder mounting bolt size?
Old Jan 14, 2019 | 04:00 PM
Rwright97's Avatar
Does amybody know the bolt dimensions to the slave cylinder mounting bolts? Also is it just two bolts holding it in or a nut on the ends aswell?
Old Jan 14, 2019 | 10:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Slave cylinder mounting bolt size?
The 84-02 bolt was shaped like a U with threaded ends. Inside the cabin, locking nuts M8 X 1.25 retained it.
Old Jan 15, 2019 | 04:45 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
That's the master though, the slave is held to the bellhousibg with 2 bolts and nuts.
Old Jan 15, 2019 | 06:58 PM
Drew's Avatar
The nuts are welded to the heatshield. Sure they're metric, probably a M6 or M8.
Old Jan 15, 2019 | 07:56 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
m8 x 45mm
CAT
Oct 20, 2025 02:26 PM
dixiebandit69
May 27, 2008 02:06 PM
