Best trans lock up for 91 700r4 without ECM
Old Mar 2, 2019 | 12:32 PM
Gus Kreis's Avatar
Car: 91 camaro rs
Engine: 4 bolt 350
Axle/Gears: Stock
I have read like 20 different things for the transloc. I'm just at a loss of what exactly I should do because if I mess something up I do not have the money to replace it. What exactly can I do for the 700 R4 and this lock up for a minimum amount of money right now I will fix it with a full kit later. It's just that the kid I got this car from left it in shambles and the ECM isn't in the car anymore. Any help would be greatly appreciated. once I have the money for it I want to get a TCI lockup kit.
Old Mar 2, 2019 | 08:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Best trans lock up for 91 700r4 without ECM
https://www.thirdgen.org/forums/tran...up-switch.html
If your looking for a cheap solution, wire up a toggle switch that will apply power or the ground of the tcc solenoid.
Old Mar 2, 2019 | 08:49 PM
Engine: Lb9
Transmission: M20
Old Mar 3, 2019 | 01:13 PM
Gus Kreis's Avatar
Car: 91 camaro rs
Engine: 4 bolt 350
Axle/Gears: Stock
I just ordered my vacuum switch
Old Mar 20, 2019 | 09:47 PM
Gus Kreis's Avatar
Car: 91 camaro rs
Engine: 4 bolt 350
Axle/Gears: Stock
the setup above with the vacuum switch works very well and being able to manually turn it on and off at anytime is a bonus.
Gus Kreis
Mar 1, 2019 06:19 PM
KITT1983
Jan 16, 2009 12:35 PM
anthony714
Feb 12, 2006 07:06 PM
GregN
Feb 17, 2002 10:02 PM
