Wont start
Car: 1985 camaro iroc-z
Engine: 350 carb
Wont start
ok now my car wont start good battery good starter & good alternator i relaced the starter to battery cable & all it does is click even if i jump the car still all it does it click
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wont start
Check your power and ground connections. If those are good get your starter tested.
wrong forum !
wrong forum !
Car: 1989 Pontiac Trans Am GTA
Engine: 350ci TPI
Re: Wont start
I had the same issue with my car, I replaced the starter and the problem went away for about 2 months.
if you want to see if it's the starter get a long rod you can hit the starter with and have someone turn the Key. I bet it'll turn on.
I ended up getting a custom starter made so I can put in long tube headers and haventh had the issue since
camarors1989v6
Oct 9, 2009 06:25 PM
camarors1989v6
Sep 8, 2009 01:43 PM
Birdsong_'89_RS
May 6, 2008 10:01 PM
84TAProject
Jan 9, 2003 07:29 PM
