Reverse drum bench testing.
Old Apr 13, 2019 | 04:58 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Air testing the reverse drum and I have leakage past the stator rings. The piston will apply but it leaks quite a bit. Is this acceptable for scarf cut rings. I used them on my other build and they did not leak but they do on this one. Reverse drum is in good shape were the rings seal. I ordered some solid ones just incase. I heard that a bit of leakage is ok since air can get by the rings better than the thick atf. Pro built wya?
Old Apr 18, 2019 | 09:29 PM
Pro Built Automatics's Avatar
Re: Reverse drum bench testing.
What pressure are you using here? Are you using the Belville steel on top of the apply piston? Or the waved steel here/ The scarf have always worked well for me. So I am not sure what is going on here. Make sure the scarf cut ring is nor overlapped the wrong way. It is easy to do, not not be noticed unless looked at closely. You can call me if you want. Number on website, if you do not have it.
Old Apr 19, 2019 | 12:35 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Using the belville plate. Yeah on my first build I used the scarf and they sealed up just fine. No leaks. Kinda weird because when I tore down this unit it had solid sealing rings and when testing the reverse drum with the old rings it sealed up just fine so I was gonna reuse them. But upon testing and removing the drum back and forth I tore one of the rings and said screw it so I removed the old ones and installed the fresh scarf cut rings . Upon testing the drum at 100 psi I have leakage past the rings. I can feel the air coming from the reverse drum bushing. The clutches still engage but I have leakage. I tested it with another pump that I have and same thing. Also tested another reverse drum that I have with both pumps and same thing. I have the solid ones just waiting trying to figure out what could be the issue before I install them.
Also when testing my forward and 3 4 clutches with the pump on the bench, reverse drum, and input housing stacked up. Reverse drum washer and bearings in place. When I apply air to the 3 4 hole the clutches engage fine but I have air coming out the forward clutch hole. Forward clutches do not engage btw. Same thing vice versa. If I apply air to the forward clutch hole, clutches engage but have air coming out the 3 4 hole. 3 4s do not engage. Is this normal. ? I don't quite remember from my first rebuild.
Old Apr 24, 2019 | 11:29 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Hey I found out I resized the input shaft sealing rings too much. Put new sealing rings on and resized them just a bit and now I have no leaks through other circuits. Thanks for the help Dana.
91FirebirdFmla
Aug 4, 2010 02:17 AM
jrg77
Apr 18, 2005 09:02 PM
Z28cross-fire
Sep 1, 2004 08:48 PM
T'dpriece
Dec 29, 2003 12:58 PM
aaron7
Car Audio
Nov 19, 2003 09:12 AM
