Fresh oil.
Old Apr 21, 2019 | 08:50 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Fresh oil.
Just changed the oil in the tranny and 9 bolt. The T5 is now enjoying a fresh fill of Synchromax and the 9 bolt is full
of Redline 75W110. T5 shifts smooth.
Old Apr 23, 2019 | 12:09 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Fresh oil.
ok....?
Old Apr 23, 2019 | 11:25 AM
Tremo's Avatar
Re: Fresh oil.
Originally Posted by IROCZman15
ok....?
Haven't taken a decent drive in it since Sunday. I'll take her out this coming weekend. The T5 is shifting very smoothly.
The drain oil was pretty black coming out of both the rear end and the trans.
Old Apr 26, 2019 | 03:21 PM
ksr's Avatar
ksr
Engine: 5.7 liter V-8
Transmission: 4 speed auto
Re: Fresh oil.
Question about this:
I bought a stock TA in February of 2018. It was well maintained, in great shape, one owner. It had 32,000 miles on it and I've put added about 3,000 miles on it now. The car runs just great.
I don't have maintenance records regarding the fluids. I've changed the oil of course and I had the brakes flushed and filled.
No idea when the rear differential fluid or transmission fluid (automatic) has been changed, if ever. Years ago I used to read warnings about older cars regarding automatic transmissions, basically saying that if you haven't changed it and the car is of a certain age, you're better off leaving it alone. I think the reasoning was that the new fluid might break down the old seals.
I tend to think that I should probably change the tranny fluid. Any thoughts? I know this is quite an old debate and I've read arguments over the years on both sides. Some people say that is absolutely a myth that new transmission fluid caused later problems and that in such cases, the transmission was on its last legs anyway.
Old Apr 26, 2019 | 06:12 PM
Tremo's Avatar
Re: Fresh oil.
I'd go ahead and change the fluid on both the tranny and rear end. And put a new filter in the tranny. Use good fluid, not the cheap **** or Iffy Lube.
TheLegedaryErin
Oct 29, 2007 09:37 PM
CamarosRUS
Jan 5, 2007 10:39 AM
NoTransistors
Aug 30, 2005 12:50 AM
D Stroy H8
Apr 11, 2003 06:29 PM
martyr
Sep 21, 2002 04:27 AM
