1991 700r4 vss speedo gear?
Old May 2, 2019 | 07:37 AM
jellyfis66's Avatar
hello, I bought a 1991 bird,305 tbi a/t and the speedo and odometer does not work so I pulled the vss off the tail shaft and there is no speedo gear attached? is there supposed to be one there?
Old May 2, 2019 | 11:51 AM
Drew's Avatar
Re: 1991 700r4 vss speedo gear?
Didja look in the hole? The gear just slips on the D shaft. There's no retainer, it can slide right off when you remove the sender.
Old May 3, 2019 | 09:43 AM
racerx520's Avatar
there should be a gear of some sort in there. not all 700r4 used VSS, some were cable driven. There is a chance someone took it out maybe? maybe they put a new rear gearing in and didnt want to see a messed up speed on the gauges? or maybe like drew said, maybe it fell out
Old May 3, 2019 | 09:56 AM
jellyfis66's Avatar
thanks drew and racerx520! I took a small mirror and flash light and saw the speedo gear laying up inside!
Old May 3, 2019 | 12:13 PM
Drew's Avatar
Just to clarify, the driven gear is generally a bit cone shaped. The drive gear will be partially visible in the hole, you'll just see the edge that drives the VSS gear.
Old May 3, 2019 | 12:59 PM
jellyfis66's Avatar
drew I love your description of your 91 rs convertible (t.b.i) toilet bowl injected. best tbi description ever!! thanks again.
Camaro-3
Apr 13, 2018 09:01 PM
Sparkytfl
Apr 7, 2012 04:13 PM
paulmoore
Feb 5, 2005 12:22 PM
ar_mcadams
Oct 9, 2004 08:30 AM
