I am confused!! Autometer Speedo vs stock speedo cable vs VSS
Old Jan 1, 2005 | 01:29 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Ok I am trying to figure out what I should do here. I currently have an 88 camaro(was a V6 but now has a 350) with a stock speedo cable. It is a WC T5. I want to use an Autometer Ultralite 200 MPH speedometer. I know that I can use the mechanical one with no real problems except for the gears in the rear(will have 4.11's) I don't want to change out the transmission gear located in the tailshaft section so I started looking at the Autometer Electronic programmable unit. It is self calibrating so there is no need to swap out speedo cable gears. But, since this speedo is electronic, do Ineed to swap over to VSS and then splice the autometer into it? I have no experience with the VSS so I'm not sure if that will work. Any help or info on this would be greatly appreciated. Thanks, Paul Moore
Old Jan 1, 2005 | 03:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Are you running an ECM?
Old Jan 1, 2005 | 03:57 PM
paulmoore's Avatar
Nope, it is a carb'd 350 with no computer.
Old Jan 1, 2005 | 07:54 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Why don't you change out the speedo gears in the tranny? That would be a lot easier than buying a reprogrammer or something.
Just change the speedo gear man.
Old Jan 1, 2005 | 08:48 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
You can pick up a VSS that plugs right into the cable port on the trans. If you can't find it in Jeg's or Summit you can probably get it from a 4x4 place. That and the electronic speedo will let you adjust for any given gear/tire combo by simply pushing a button, driving 2 miles, and pushing it again. You'll also still be able to use it if you ever go T56, or back to EFI.
The mechanical speedo is a good bit cheaper though.
Old Jan 1, 2005 | 08:49 PM
jmd's Avatar
jmd
If you have no cruise and have no ECM then placing a VSS into the trans instead of the cable drive gear / sleeve will work fine.
Old Jan 2, 2005 | 03:16 PM
paulmoore's Avatar
Yeah, I also don't have cruise control either so I guess that should work then. Just get a VSS from a 5 speed f body, put it in the transmission, and then run the wires from the VSS to the speedometer. Thanks for your help on this.
Old Feb 4, 2005 | 11:13 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
could i run a 97 lt1 speedo off a firebird(tranny mounted) VSS?
i have a buffer box, but im not sure if ill need it now.
might have to hook up the vss and see if she works.
Old Feb 5, 2005 | 12:18 PM
jmd's Avatar
jmd
Depends on which firebird VSS.
Third gen firebird? Yeah.
Old Feb 5, 2005 | 12:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
sounds to easy, im gonna have to give it a shot.
thanks.
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
