Is there a Gasket inbetween the TV cable and tranny?
Old Jan 9, 2002 | 09:31 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Where the TV cable bolts down with 1 bolt. Is there a gasket in between there or should i use rtv.
Old Jan 9, 2002 | 09:49 PM
MotorCityMuscle's Avatar
Yes, oh *** yes theres a gasket in there. I didn't think there was and caused the mother of all transmission leaks a few weeks a go. You can get it at Autozone etc and it cost me I think $6. Just make sure to get all the remains of the old seal out or the new one'll never go in.
Old Jan 10, 2002 | 12:14 AM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Also disconnect it from the carb or throttle body first or you will never get it out. You just need to disconnect it from the linkage to release the tension on the spring in the tranny. Don't be afraid, the rod will not fall into the pan. They made it for idiots like us
Old Jan 10, 2002 | 04:15 AM
Pro Built Automatics's Avatar
It is a TV top hat seal, costs about .35 cents. Most people forget to take out the old one, this causes... well you know what. Make sure you oil the seal first, and do the install carefully.
Old Jan 10, 2002 | 11:09 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
the top hat seal is for the dip stick, the TV cable is just an O-Ring atleast thats how it was with mine
Old Jan 10, 2002 | 03:53 PM
That is probably the reason it is leaking. It takes a top hat seal similar to the dipstick.
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
L0tuS
Oct 4, 2015 08:07 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
IROCZ1989
Sep 4, 2015 11:54 AM
