9 bolt yoke help
Old May 26, 2019 | 01:38 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
9 bolt yoke help
Just rebuilt my 9 bolt, started putting back together last night to check the pinion depth. All went together fine, but needed to add few shims and recheck my contact pattern. Got back at it today, taking the yoke back off, added shims, went to put the yoke back on and now I have this gap despite the pinon bolt being tightened as far as it can go. I'm not sure if I'm overlooking something from last night till today, but I have a gap now that wasn't there last night. I even took the shims out and tried it again and same gap that was not here this morning when I took it back off. Very confused.......
Old May 26, 2019 | 03:00 PM
big gear head's Avatar
Re: 9 bolt yoke help
You didn't install the crush spacer yet did you? If you did then remove it and save it for the final assembly.
Old May 26, 2019 | 03:11 PM
Car: '89 Iroc
Engine: 383 TPI
No I don’t. Should there be any space like that or should it be flush technically?
Old May 26, 2019 | 08:00 PM
Did the bearings get tight when you tightened the pinion nut? If they did then it's probably right.
Old May 26, 2019 | 09:47 PM
Car: '89 Iroc
Engine: 383 TPI
Yes it was all tight and seems good to go, thanks.
88'camaro305TBI
Jan 28, 2019 01:41 PM
zya5point0
Sep 29, 2017 02:34 PM
89 Iroc Z
Mar 10, 2003 10:45 AM
crazeinc
Jul 7, 2001 10:52 AM
