T5 speedometer gear
Old Jan 10, 2002 | 08:59 AM
83 MidniteZ's Avatar
T5 speedometer gear
My speedometer gear inside the transmission is worn, and I was thinking about pulling it apart to replace it. Are there any specail tools needed to perform this. Also, do I need to get any gaskets or special sealant to put it back together? Anyone performed this themselves?
Old Jan 10, 2002 | 05:05 PM
plain82's Avatar
Drive gear or driven gear? The driven gear comes out of the side with just a 10mm wrench. The drive gear involves removing the tailhousing, which then needs to be resealed with RTV.
Old Jan 10, 2002 | 05:26 PM
I was referring to the drive gear inside a T5
Old Jan 11, 2002 | 05:59 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
No special tools needed. Just some sockets, estensions, and maybe an impact wrench as a backup.
Get the car off the ground as high as possible since you need to remove the tranny in order to remove the tailshaft.
I used Ultra-Black RTV for the seal, no gaskets needed. BTW you may want to replace the tranny output shaft seal (about $3 from NAPA)
Hope this helps.
Old Jan 12, 2002 | 10:15 PM
plain82's Avatar
Hey, Pukka, what gears does your tranny have? Does your speedo read correctly? I have the same gears and my speedo is off by 12 MPH. It reads 77 MPH when I'm going 65.
Old Jan 12, 2002 | 10:58 PM
Pukka's Avatar
I have the stock B&W T-5. Changed the speedo gears when I upgraded the rear end. Before I switched speedo gears the speedometer read about 10% faster than actual speed
Old Jan 12, 2002 | 11:39 PM
plain82's Avatar
I was wondering what gears you installed. I've got 3.42 gears in the rearend and mine is off by 12 mph. I've got the red drive gear and a white driven gear. Oh, yeah, I've got an 88 T5 in my 82.
Old Jan 13, 2002 | 07:08 PM
Pukka's Avatar
I forgot the part numbers for the drive and driven gears, but the drive gear is blue.
Just call a GM parts place and tell them you want the 3:42 gear set. They should be able to order the parts, cost was about $20 for both gears
Old Jan 13, 2002 | 09:06 PM
plain82's Avatar
Thank you for your time and patience, sir.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
