Mini Spools and Rear Gear Swap
Old Jul 17, 2019 | 08:26 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I'm the original owner of a 1991 RS with the original TBI motor. The rear is starting with low whine so I'm considering changing the ring and pinion. It's an automatic car with the original 2.73 gear and I want to go to a 3.73 gear and install a mini spool and obviously a rebuild kit. Has anyone tried this especially in terms of the mini spool. I'm interested in the results and RPM while cruising at 65-70 mph on the highway. Thanks!
Old Jul 17, 2019 | 09:36 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Mini Spools and Rear Gear Swap
I'd put a locker in it before a spool
Old Jul 17, 2019 | 11:07 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would never put a mini spool on a street car. If you are putting in new gears you might as well get a new POSI. A zexel from a LS1 posi rear will be a good used option. Otherwise eaton or yukon duragrip are popular. Going from 2.73 to 3.73 you are up about 500RPM at the same speed.
blue birdy 87
Nov 14, 2011 08:01 AM
Nightrider350
Sep 16, 2005 04:37 PM
pokes87iroc
Jun 21, 2002 06:05 PM
jester731
Mar 18, 2001 09:33 PM
