TH350 Rebuild
Old Jul 26, 2019 | 11:25 AM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
TH350 Rebuild
For all the ones that have messed around with any certain types of tranny rebuilds, whether that be a th350 or any gm trans, I would like to know what rebuild kit you got and how you liked it.
Old Jul 26, 2019 | 03:43 PM
Pro Built Automatics's Avatar
Re: TH350 Rebuild
I have the "complete" rebuild kits for the TH350's. What is the horsepower? Torque converter being used? 2WD or 4WD? Weight of the vehicle? etc.
Old Aug 16, 2019 | 01:58 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: TH350 Rebuild
whats the highest hp a th350 is good for ?
Old Aug 18, 2019 | 04:26 PM
Re: TH350 Rebuild
That is a "loaded question". Depends on weight, diameter and stall of the torque converter, stock type sprag or 36 element type sprag, how it is built, etc.
Old Aug 18, 2019 | 07:25 PM
69L48Z27's Avatar
Car: 1989 IROC-Z
Engine: 5.7L
Re: TH350 Rebuild
In stock form GM used TH350’s on small blocks and Turbo 400 on big block cars if that’s any indication. You can build to probably 450-500 ft lb but I would use a newer trans or the TH400 for anything really over ‘stock’.
HottestZ28
May 4, 2008 11:35 AM
1986redbird
Feb 19, 2003 06:15 PM
86budgetSC
Jan 10, 2003 02:50 PM
Cynsguy
Jul 12, 2002 10:54 PM
