Just making sure I understand what I need for a T-56 swap
Old Jan 11, 2002 | 04:42 PM
Yarnboy's Avatar
I am buying a '93 T-56, clutch, bellhousing and flywheel. Is there anything else I will need? Will I need an aftermarket crossmember? What will I need for the speedometer? Will I be able to use my hydrolic assembly? Or will I need that too? How can I tell weather or not the T-56 has the steep gears or not? Can I use the ES tranny mount I have now?
Old Jan 11, 2002 | 06:42 PM
u r sofa king we tah did's Avatar
you will need the master/slave cylinder kit from gm for a 93-94 six speed car. and for the speedo, since your car is MAF, you will need the cable-x. do a search for it on this board. the poly tranny mount will work. im not sure to tell how if your 93 six speed is the wide ratio. maybe get some numbers off of it would be the only way i could think of.
Old Jan 12, 2002 | 01:10 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
There is a tech article on this site that gives you a list of everything you need to do the swap. By the way I'm so jealous. I wish I had a 6 speed
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
mizz0313
Aug 12, 2015 06:45 AM
cRoe4
Aug 7, 2015 08:46 PM
