What I found in my trans pan 700r4 (spring) and boost valve stuck
Old Sep 20, 2019 | 04:33 PM
c4mo's Avatar
Changing the fluid in my 700r4 I find this grayish material in the pan and this spring stuck to the magnet. Can anyone identify it?
Old Sep 20, 2019 | 04:49 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: What I found in my trans pan 700r4 (spring)
That's called the rebuild spring; when you find it in your pan you need to have the trans rebuilt.
Jokes, but your pan looks pretty darn bad.
Old Sep 20, 2019 | 05:25 PM
Billgluckman's Avatar
Where the tv cable goes into the trans I’m pretty sure it connects straight to a spring. Might want to make sure the tv cable is working.
Are you having trans problems? Sure looks like clutch material in the pan.
Old Sep 20, 2019 | 05:55 PM
c4mo's Avatar
Tv cable is intact and working fine. This car has been In storage for a few years because I had thought the trans went out but now it seems to be working ok. The reason I thought it went out was I was shifting manually 1-2 one day and it made a bad grinding noise. Now oddly getting it running again it shifts fine. I will upload more pics.
Old Sep 20, 2019 | 07:45 PM
c4mo's Avatar
I checked the line pressure when I got it running again in July and found that pressure was low in manual 1 and 2. I spoke with Dana at Probuilt and he advised checking rev/intermediate valve above the boost valve to see if it was possibly installed upside down. Tonight I removed the snap ring below the boost valve and it would move a little above the snap ring, but when I try to remove it to check it out I find it’s stuck in the bore. Any suggestions to get it out? I saw on another thread to try to blow air where the filter neck goes in?
Old Sep 21, 2019 | 09:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What I found in my trans pan 700r4 (spring) and boost valve stuck
Put the pan back on, add a couple of quarts of fluid, start engine.
RBob.
Old Sep 21, 2019 | 07:26 PM
c4mo's Avatar
Thanks for the suggestion that did work, I did find out that the boost valve is a .500 but the int/rev valve was only .218 so I spoke with Dana and have a .296 valve coming.
Old Sep 22, 2019 | 08:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You're welcome, that is a tip that Dana posted here. When you install the boost valves, be sure that the c-clip goes into the groove. There is a step in the bore prior to the c-clip groove that is easy to mistake for the groove.
And sometimes it can be difficult to get the upper portion of the line up past a certain point in the pump.
As for the spring, I don't see anywhere in the 700R4 that it is used. Maybe someone dropped it down the dip stick tube?
RBob.
Old Sep 22, 2019 | 10:14 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Use a socket to push the c-clip and boost valve in all the way. Worked every time for me.
Definitely looks like the TV cable spring, might just be an extra.
Old Sep 24, 2019 | 02:19 AM
Pro Built Automatics's Avatar
The spring kind of looks like the one used to hold the parking pawl lever to keep tension on it away from it hitting the gear when is not in park.
MikeCpa
Nov 5, 2015 05:42 AM
Baxbird89
Sep 19, 2014 11:14 AM
Arts89Iroc
Oct 4, 2013 03:35 PM
srosscamaro@aol
Jan 13, 2010 07:40 PM
BADMAN
Aftermarket Product Review
Dec 1, 2006 11:20 AM
