T56 PCM?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: T56 PCM?
The t56 doesn't need a pcm, bcm or ecm. having a vss signal sent to the ecm if your not running a carb on the ls will help with iac control.
Re: T56 PCM?
I did a swap on my 88 TBI Firebird and have all the stock gauges working. The only gauge that isn't accurate is the fuel gauge but that's because of the LS fuel sender. I'm going to try the V6 fuel sensor.
My initial plan was to install aftermarket gauges but that will have to wait until this virus is gone.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: T56 PCM?
T56 requires only 2 electrical connections at the minimum.
#1 is the VSS Speedo signal. Black and Purple wires.
#2 is the Reverse Light switch.
However, also helpful to have is a Reverse lockout wiring which will let you shift into reverse easier. However, I haven't run it ever, and it just needs some muscle to put it into reverse. I do intend to wire it up one day since I'm running a LT1 I just need to run the feed from the PCM through the harness and it will disengage the lockout under 5mph. An alternate to the wiring is to cut or replace the spring which reduces the effort needed to put it into reverse, but does open the possibility of accidentally selecting reverse when going from 4th to 5th.
ChevyRS-305
Dec 6, 2010 12:02 PM
