thinking about going with a zf6
Old May 23, 2020 | 11:02 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
i found a deal on 94 zf6.
I know it will be a lot of work. can i use the lt1 bell housing and convert to hydraulic throw out bearing.
I know I will need a custom cross member and torque arm mount, custom drive shaft and trans tunnel modification.
I think the vette used a pull type clutch. What did the firehawk use for a clutch setup. I know they used a custom bell that had provision for the t5 slave cylinder, but was there a specific clutch and pressure plate?
Thanks,
Chris
Old May 24, 2020 | 05:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: thinking about going with a zf6
Originally, the 89-96 L98, LT1, and LT4 models used a dual-mass flywheel.
Instead of a clutch disc with sprung center hub, the flywheel had the sprung hub. The clutch disc was solid. Then, they had the same Valeo pressure plate as the 93-97 4th gen.
The flywheels were limited availability, last I checked. Going with a different clutch set-up can make the S6-40 trans. make noise.
The Firehawk, if memory serves, used the Vette aluminum S6-40 bellhousing, modified to fit. Magnesium bells were used in some but not all Vettes. Hydro TOBs have been adapted to the trans; Ram used to offer a setup.
The Firehawk floor had a shifter opening hump welded on and the console was different to suit the S6-40 shifter location.
The S6-40 speedo drive was speedo gear driven VSS, like the third gens.
The S6-40 is strong, but parts to service a T56 or TR6060 are going to be more available for longer. While the argument could be made the S6-40 is stronger than a T56, it's really the only argument to go with it at this point.
Old May 24, 2020 | 08:19 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
well the deal on the zf6 fell through, so sticking with the wct5 for now.
thanks,
Chris
ZCanuk
Jun 4, 2024 01:30 PM
85_SS
Dec 26, 2007 12:59 AM
TBI92Camaro
Dec 21, 2006 05:43 PM
91RedRagtop
Sep 18, 2005 10:38 AM
BigKid
Mar 3, 2002 06:21 PM
