Q about changing backup light switch. T56
Old May 28, 2020 | 11:10 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Hi
Do I have to drain the oil in order to change the backup light switch on a B&W T56 transmission?
Old May 28, 2020 | 09:15 PM
Screamin82 Z28's Avatar
Car: 82 Z28
Engine: 383 SBC
Axle/Gears: 3.50 9 inch
Re: Q about changing backup light switch. T56
Not likely. As long as it's above the fill plug (drivers side) you should be good. I can measure it up tomorrow if you need to make sure.
Old May 29, 2020 | 08:27 AM
Car: 82 Z28
Engine: 383 SBC
Fluid level approximately 4in from bottom of trans. This switch is about 6in up. A little dribble is all I would expect.
Old May 30, 2020 | 01:58 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No.
Lift that side of the vehicle. Change out the switch. Done.
Hotrodder
May 24, 2020 12:55 PM
5.0 Eater
Jan 27, 2010 02:36 PM
Naga1337
Mar 7, 2008 10:37 PM
82zm6
Jan 15, 2002 05:30 PM
