T5 clutch pedal/no pressure
Car: 88 camaro iroc
Engine: 5.0 TPI
Transmission: 5 spd mannual T5
Axle/Gears: 3.27/ 9 Bolt
Today, driving back home from work this happens (By the time i'm about 1/2 of mile to get home) .Coming to and off a stop sign I felt very little pressure on the clutch pedal and I can feel difficulty to put the transmission in gear, so I drove it in 1st gear for the rest of the way home. Once I got home I did a visual inspection and no fluid leaks were found. I had my brother to step on the clutch pedal, again no leaks but I do hear a "ding" or metal to metal sound coming from inside the transmission bell housing every time the clutch pedal is pressed all the way down.Does anyone know what the problem might be? Thanks. 88 camaro tpi 305 t5 transmission. By the way the transmission was rebuilt about 40, 000 to 50,000 miles ago and clutch replaced about 65,000 mile ago.
Sean2857
Aug 6, 2007 10:53 AM
