Driveshaft for 3rd gen
I recently swapped a v6 motor for a 305 and put a 350th short tail trans in my car. I’m having a hard time finding a drive shaft that will fit. The stock driveshaft is about 2 in shorter. This is my first time needing a drive shaft and I honestly am not sure what to look for. Any help is appreciated
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Driveshaft for 3rd gen
Car: check
Engine: check
Transmission: check
I think that one for an '82 or '83 will be the proper length. As they didn't have the OD transmissions. Could always get a new one from a place such as Denny's.
RBob.
RBob.
Car: 89 IrocZ
Engine: L98-ish
And you could look through the phone book, find a machine shop near you who can fix you up. Just my guess if I had the perfect shaft for you, and I mailed it to you, it would be as much or more than doing it local and having it made or yours altered.
Does anyone actually go to a shop anymore, or live online and ...
Never mind.
Never mind.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Can anyone confirm the length of the 82-83 Driveshaft should be ?? Best I can come up with so far is 3" longer than the 700R4 version = 44 1/2" Just looking to confirm this info.
https://www.thirdgen.org/forums/tran...h350-swap.html
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Just have one built and stop guessing, these guys do top notch work and will be better than anything stock
https://pstds.com/
https://pstds.com/
