Th400
Old Sep 4, 2020 | 04:10 AM
LDR's Avatar
LDR
Car: 2012 Impala ltz 1988 Gta project
Th400
Ok I’m reading the threads and numbers are all over. I’m looking to get a driveshaft for my th400 install. From what I read it sounds like I need a 47 inch driveshaft. Am I reading that right. I got this trans with a yoke but I’m not sure I feel safe with the yoke. It’s 6inches long after the joint leaving 4inches exposed with the full engagement. I mean it’s long enough I can hook to the factory third gen driveshaft.
Old Sep 7, 2020 | 04:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Th400
That's an extended Yoke, do what should be done a get a proper one, then do to the many sites that show you how to measure for a drive shaft...suggestion though...find a shop locally and ask them...if you use their measurements and the shaft is too long or short, they will have to make it right. If you order on line and order wrong, you will now have an extra drive shaft in the corner of the shop.
dmwracing42
May 8, 2020 05:49 PM
nowerelsetoroam
Feb 13, 2013 05:17 PM
rczanstke
Dec 23, 2011 04:40 PM
james_85Z28
Southern California Area
56
Jun 13, 2006 11:15 AM
