Transmission Won't Shift into 1st Gear or Reverse at Times
Old Oct 4, 2020 | 09:27 PM
90sRSCamaro's Avatar
Car: 1991 Camaro RS
Transmission: T5 manual
My 91 Camaro RS with the 305 5speed transmissions at times when parked or at standstill won't let me shift it into 1st gear or reverse. I can take off slowly in second gear and then shift to 1st and it'll go into gear. It just won't go into 1st when I'm stopped. When I go to put it in reverse sometimes it won't go into gear either till I shift it into a different gear and then go back to reverse. Both of these problems, however, happen only a few times and most of the time my Transmission works perfectly fine. It doesn't grind or anything when I shift into gears, so why is my transmission doing this at random times and how can I fix it?
Scorched1984
Jul 22, 2016 02:04 PM
warford574
Dec 29, 2009 08:41 PM
bigj85z-28
Jan 21, 2006 04:44 PM
