700r4 Torque converter
Old Dec 12, 2020 | 04:47 PM
VikingCamaro's Avatar
Car: 1988 camaro
While trying to install my torque converter I am only able to get it to slide down so that the pads are level with the bell housing. It makes one loud click and then does nothing regardless of how you spin it or hold it, I have put a torque converter on a Th350 and didn’t run into any problems. Any idea what this could be, or if there are any tricks to 700r4s. Thanks.
Old Dec 12, 2020 | 06:51 PM
NoEmissions84TA's Avatar
Re: 700r4 Torque converter
AFAIK, no tricks. I believe there should be 3 clicks. Just keep rotating the converter with a little pressure pushing on it.
Unless you are absolutely sure that it is fully seated, do not proceed any further.
Old Dec 13, 2020 | 04:28 AM
Pro Built Automatics's Avatar
You must be able to push the transmission by hand, flush with the block, and still be able to turn the torque converter. IF NOT, you will break the pump. Try a "dead blow" hammer, and whack it easily, while spinning the torque converter. On the final click, it should go aways back into the bell housing, when seated.
Tim91RS
May 2, 2008 12:09 PM
dyed
Mar 8, 2008 03:31 PM
limptrzkit
Pacific Region
Jul 26, 2006 08:00 AM
12SecondTA
Feb 5, 2006 10:29 PM
