Posi rear identification
Old Dec 13, 2020 | 08:48 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I am trying to figure out what manufacturer made this posi gear. It looks like an Auburn from pics I have seen but it has that added "gear" on the pinion gear? Is this an Eaton? Most of the pics I see the pinion gear does not have the added gear. I assume that gear is part of the carrier and not the pinion itself. Also what does that gear drive?
Old Dec 13, 2020 | 10:58 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Posi rear identification
looks like that might be from an early 4th gen-the gear like piece is a "tone ring"-there is a magnetic pickup that is close to the teeth that creates a variable frequency impulse as the gear rotates for the speedo or ABS brakes.93-97 4th gen used the Eaton posi.
Old Dec 13, 2020 | 11:49 AM
GeneralDisorder's Avatar
That's just a carrier with an ABS tone ring. Still an Auburn. Still junk.
GD
Old Dec 13, 2020 | 11:58 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I notice it has springs just like an eaton posi. How can you tell the difference between auburn & eaton? Is it the tapered end of the carrier case that tells them apart?
Old Dec 13, 2020 | 01:42 PM
The cast, unmachined carrier, tapered ring gear mount, etc. It's a 4th gen 3 series Auburn - in other words - "scrap metal"
GD
Old Dec 15, 2020 | 02:07 PM
vinny R's Avatar
Car: 1991 Z28
GD
Thanks guys for the info
GD why you got to hate on other peoples junk! This Scrap metal rear came with the rest of this heap of the same. But as long as my Junk keeps this up, the mistress will be happy!
COTY'S IROC-Z
Sep 17, 2010 09:04 AM
Winger4800
Jul 27, 2005 08:03 AM
92lt1
Aug 8, 2004 02:37 PM
LeeH
Jun 21, 2004 09:37 AM
