10 bolt rebuild - y5e06
Old Mar 31, 2021 | 12:33 PM
y5e06's Avatar
Car: itsa '85 LG4 S/E Turd 'Bird
Engine: Wheezy 305
Axle/Gears: 10Bolt, 3.42s, TruTrac
just some pics, I put most of my stuff on IG and don't contribute to TGO as i should.
'85 firebird 305 quadrajet 700r4. its a turd. the rear diff was whining terribly when I bought the car a few months back. Probably the worst I've ever heard.
I was planning on doing a simple refresh but discovered it was a 9bolt and not a 10bolt as expected. Common experience seems to say the 9bolt is stronger. I didn't care that much and I wanted ease of rebuild and parts so I pulled a 10-bolt drum rear out of a '92 305 camaro to rebuild. I have a full LT1 brake setup to swap later, I didn't feel like dealing with those neaunces right now.
-10 bolt drum car.
-3.42 gears from 3.08. bought used on ebay, setup (paint) pattern will be a bit different
-Detroit Tru Trac Hellical diff
-Ratech rebuild kit with all new Koyo (made in USA bearings), seals, etc and their smart-sleeve (crush sleeve)
-stock axles. good enough for my power level and future LT1 brake swap.
-welded on drain plug
-fab'ed control arm and track bar relocation brackets; I plan on dropping the car 2" front 2.5" rear in the future
-new shoes, cylinders, hose
-cleaned & painted everything
0.075 backlash
22 inch-pound pinion bearing pre-load. some will say thats alot but '85 & '95 firebird manuals spec 15-30 inch-pounds preload and another 2-5 for a completed assembly.
starts off with junkyard crawl pulling the diff out of the donor. what a PITA.
Attached Thumbnails 10 bolt rebuild - y5e06-screenhunter_1352-mar.-31-12.20.jpg   10 bolt rebuild - y5e06-screenhunter_1353-mar.-31-12.20.jpg   10 bolt rebuild - y5e06-screenhunter_1354-mar.-31-12.20.jpg   10 bolt rebuild - y5e06-screenhunter_1355-mar.-31-12.21.jpg   10 bolt rebuild - y5e06-screenhunter_1356-mar.-31-12.21.jpg
10 bolt rebuild - y5e06-screenhunter_1357-mar.-31-12.21.jpg   10 bolt rebuild - y5e06-screenhunter_1358-mar.-31-12.21.jpg   10 bolt rebuild - y5e06-screenhunter_1359-mar.-31-12.22.jpg   10 bolt rebuild - y5e06-screenhunter_1360-mar.-31-12.22.jpg   10 bolt rebuild - y5e06-screenhunter_1361-mar.-31-12.22.jpg
Old Mar 31, 2021 | 12:37 PM
y5e06's Avatar
Engine: Wheezy 305
Re: 10 bolt rebuild - y5e06
continued. shop dog included.
https://share.icloud.com/photos/0JI_...MT0tnLDXaSsoYA
https://share.icloud.com/photos/05sc...RfebY75-N3QbJg
relocation drop seems a tad much but i plan on dropping the car 2.5" in the rear. I measured to get flat LCA's. also have a few extra hol3s if I want to change my instant center.
Attached Thumbnails 10 bolt rebuild - y5e06-screenhunter_1362-mar.-31-12.23.jpg   10 bolt rebuild - y5e06-screenhunter_1363-mar.-31-12.24.jpg   10 bolt rebuild - y5e06-screenhunter_1364-mar.-31-12.25.jpg   10 bolt rebuild - y5e06-screenhunter_1365-mar.-31-12.25.jpg   10 bolt rebuild - y5e06-screenhunter_1366-mar.-31-12.26.jpg
10 bolt rebuild - y5e06-screenhunter_1367-mar.-31-12.27.jpg   10 bolt rebuild - y5e06-screenhunter_1368-mar.-31-12.27.jpg   10 bolt rebuild - y5e06-screenhunter_1369-mar.-31-12.27.jpg   10 bolt rebuild - y5e06-screenhunter_1370-mar.-31-12.28.jpg
Old Mar 31, 2021 | 12:59 PM
y5e06's Avatar
Engine: Wheezy 305
calibration to determine 700R4 speedo gear changes to correct the reading as well as a shot of 'Turd Bird' after I picked it up few months ago.
Attached Thumbnails 10 bolt rebuild - y5e06-screenhunter_1374-mar.-31-12.57.jpg   10 bolt rebuild - y5e06-screenhunter_1371-mar.-31-12.29.jpg   10 bolt rebuild - y5e06-screenhunter_1373-mar.-31-12.29.jpg
Old May 7, 2021 | 05:04 PM
y5e06's Avatar
Engine: Wheezy 305
40/15 gear combo was about perfect to dial in the speedo. I think the parts were $45 on amazon including the aluminum speedo housing.
and only because it looked so terrible in the original pic i'm posting an update. It is now shiney:
Attached Thumbnails 10 bolt rebuild - y5e06-screenhunter_1872-may.-07-17.02.jpg
Old May 7, 2021 | 07:59 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Good work.
J.C. Denton
Jan 13, 2020 11:05 AM
mike22115
Mar 3, 2017 12:04 PM
Sierra XB
Feb 28, 2011 08:30 PM
Riss
Feb 23, 2011 07:54 PM
hoogabooga
Dec 12, 2004 10:44 AM
