My Car (automatic) Will not reverse, park or overdrive
Old Jun 27, 2021 | 12:07 AM
gscroll's Avatar
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
I finally got my Camaro back on the road today, or so I thought.
After being on the highway for a bit I made a stop. After starting the car back up, it jerked forward and had to step on the brake ( it was still in park, mind you). I tried shifting to D, it felt different and noticed it wasn’t even engaging Reverse, Neutral or Overdrive as I shifted down. Normally you’d hear those clicks, but this time nothing.
Well on the road I right away noticed the Rpms were getting very high and it wouldn’t go faster then between 20-30mpg. It was going 60-70 RPMs and it wouldn’t budge. I had no choice but to pull over into a gas station as it was getting hot under the hood and temp was going up. Even my new fans couldn’t stop it and I didn’t want to risk overcooking the engine or the transmission.
So what do you all think?
Old Jun 27, 2021 | 11:21 AM
vorteciroc's Avatar
Top Answer: 1
Re: My Car (automatic) Will not reverse, park or overdrive
The first thing to inspect is the Gear-Selector Cable and Linkage to the Shift-Shaft on the Driver-Side of the Transmission.
Old Jun 27, 2021 | 11:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The cable could have broken, or the plastic that holds the sleeve to the selector in the car may have broken
Old Jul 10, 2021 | 02:29 PM
gscroll's Avatar
Car: 91 Z28
UPDATE: It was the shifter cable. It must have snapped when I pulled over. But it’s also the original one so hopefully the one from NAPA will be good.
1984z28camaro
Feb 10, 2009 01:23 AM
Z2EIGHT
Mar 2, 2007 12:03 PM
DocHoliday
Dec 18, 2005 11:44 AM
IROC'N
May 27, 2004 05:58 AM
67 Camaro 88
Aug 25, 2003 12:51 PM
