WHOA! It drives by itself!!
Old Feb 28, 2007 | 08:06 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I noticed this a few days ago, I went to reverse and it started backing up by itself!! I was like what the heck, but it ended up being useful. It was idleing at 500 and then I took it in for repairs and it idles at 700 now! It still moves the same at like 1 - 2 mph.
I'm just checking if it is normal for these cars or not. My mechanic said it was normal so whats your opinion?
Old Feb 28, 2007 | 08:13 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
isn't that what usually happens when you put your car in gear and take your foot off the break...
Old Feb 28, 2007 | 08:21 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Basically every car I've driven has done.
Old Feb 28, 2007 | 08:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
my car even with 2800 stall will move in reverse and drive sometimes.
my dodge spirit will climb small inclined hills in drive and no gas! that thing has lowend
Old Mar 2, 2007 | 10:54 AM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
ummm for real
are you for real? ...<.< >.>
Old Mar 2, 2007 | 11:22 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yeah, my car does it too.....I thought it was just me
Old Mar 2, 2007 | 11:24 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Hey, take it easy. There was a time none of us knew what an oil change was. Or which pedal was what. I still remember learning to drive a stick(stupid ditch got in my way).
As long as your idle speed is in within spec while in drive and the brake pressed, then you have nothing to worry about.
If it is higher than it should be, you may have a vaccum leak, or other issues.
Oh, and if your mechanic didn't actually do anything, then nothing should have changed.
Find out exactly what he did, if anything. Why he did it would be nice as well.
Old Mar 2, 2007 | 12:03 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
