auto to manual
Old Jan 16, 2022 | 02:15 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
auto to manual
How hard is it to swap over the 700r4 to a t5? 3rd gen getting harder to find good ones. Other than the parts. What has got to be done to get the body ready
Old Jan 16, 2022 | 05:01 PM
Re: auto to manual
Only things different about the body are the shifter hole, and the clutch master cyl hole. The console top is different in the Camaro; not sure about Firebirds, kinda seems like there's more to the console in those, and it varies from year to year.
You need the WHOLE pedal assy including the 2 little bracing brackets, the hydraulics, bell hsg, flywheel, pilot bearing/bushing, clutch, throwout, shifter, "lower boot", and ... a transmission. Good luck with that. They're getting REAL scarce. Especially the 2nd design (you don't want a 1st design), and ESPECIALLY the better V8 version with the .73 5th.
As far as "hard", probably no harder than brain surgery is to a brain surgeon. OTOH I doubt you want ME inside your skull with a scalpel. Your call on that.
Bruce Compton
Feb 11, 2015 09:55 AM
305blackbird
Nov 16, 2006 02:04 PM
n8sz28
Aug 24, 2005 09:54 PM
