LSD or Open Differential
Old Feb 18, 2022 | 03:45 AM
MichiganWildcat's Avatar
Car: 1985 IROC Z
According to my RPO. I'm supposed to have a 3.42 LSD in my 1985 Iroc. However, the guys that work on her said it's an "open" differential. I tried the old jack the axle up routine and spun the wheels. First, we spun them and they were spinning opposite each other. Then I held my side and we tried to spin the other wheel and with this scenario I was able to stop the other wheel from spinning. I know the best thing to do is just open her up and look at the carrier. In lieu of this, any thoughts as to what I really have here?
Old Feb 18, 2022 | 07:28 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: LSD or Open Differential
They do fail especially those stock Auburn units. Pop it open and look. Replace it with an Eaton or Yukon unit.
Old Feb 18, 2022 | 07:30 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
There is a very good chance some time in the last 37 years someone swapped the rear end with another to fix an issue. Pull the cover and see what you got.
Old Feb 18, 2022 | 06:29 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
My 1984 T/A was born with a peg leg. This spring I am going to install a Yukon Gear. Not cheap but my '72 Buick GS had a posi that I installed and so will my T/A.
Old Feb 18, 2022 | 07:21 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
There are some types of gear driven limited slips that will act like an open differential when the tires are loaded one way, and then the gears will lock up when the tires are loaded a different way.
KR81
Oct 13, 2020 05:11 AM
evilemokid94
Oct 11, 2011 07:00 AM
IROCJoyce
Jun 2, 2006 11:21 PM
lizardkng
Mar 13, 2006 03:54 PM
Mark A Shields
Carburetors
Oct 4, 2002 12:06 PM
