10 bolt truetrac help
Old Apr 21, 2022 | 02:51 PM
Sav2319's Avatar
Car: 1987 Iroc-z
Hi guys, I’m rebuilding my 10 bolt and am having issues with the figment of the carrier. I’m replacing the clutch type posi with a truetrac from Eaton and according to the website and after a phone call it looks like I ordered the correct part number (911A319) I’m running 26 spline axles and 3.73s. The issue is there’s no room for shims in the flange side of the carrier, like it’s pushed too far over when installing. It looks like the deck height is different from the carrier I pulled out but according to Eaton it should be a direct swap. Any thoughts? Thanks!
Old Apr 21, 2022 | 08:30 PM
Re: 10 bolt truetrac help
Sounds like you probably have the thick "swap" gears. For putting high ratios on a low-ratio carrier. Most likely the carrier you pulled out is a 2 series, and the one you're putting in is of course a 3 series.
You need the right gears. Regular thickness. Probably the gears you have were chosen to match the 2 series carrier.
knight72
Aug 10, 2015 09:32 PM
bungo78
Jun 12, 2011 07:50 PM
IAGTA
Mar 3, 2011 09:01 PM
ta3ff
Nov 23, 2005 05:15 AM
Grizzlee
Jun 30, 2004 03:23 PM
