700r4 problems
700r4 problems
i have an 83 z-28 with a 700r4.
when the car is cold it will ocassionally slip out of gear, the transmission revs freely. if i get off of the gas, it will take gear again. i am not sure how many miles the transmission has on it but it is a later model 700r4 than would have been in my car. i have experienced the problem in gears 1, 2, and 3.
Any Ideas?
Any Ideas?
A simply thing to check would be the amount of fluid in the tranny. If your on the low side, you maybe not retuning the fluid as fast as the pump needs it (cold fluid). Another thing might be to replace the filter in the pan. Good luck
Re: 700r4 problems
Any Ideas?
Any Ideas?
You may need a rebuild, your clutches and band may be burned out. If you need a rebuild the best place i've found for price is www.netgearhead.com
someone972
Aug 30, 2015 12:52 AM
