700r4 issues
Old Jul 24, 2022 | 07:26 PM
Redd86's Avatar
700r4 issues
I have searched the forums and can't find a problem similar to mine. Car is an 86 with a sbc and 700r4. Took it for a spin around the block, backed it into its parking space and left it for a couple of days. Went out today to start it, revved it up and I'm going backwards. I cycled it through gears and no change, also checked linkage on trans. It seems to be moving through gears. Any ideas? TIA.
Old Jul 24, 2022 | 07:52 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 700r4 issues
Does it have enough fluid? Does the fluid smell burned?
Old Jul 24, 2022 | 08:04 PM
Redd86's Avatar
Re: 700r4 issues
fluid is fine with both aspects.
Old Jul 24, 2022 | 08:20 PM
vorteciroc's Avatar
Top Answer: 1
Re: 700r4 issues
I am sorry, what is the issue...
The Transmission is operating as if it is in Reverse, regardless of what position the Gear-Selector is in?
...or are you saying that it behaves as if it is in Neutral, and it is rolling backwards?
Old Jul 24, 2022 | 08:37 PM
Redd86's Avatar
Re: 700r4 issues
now by burnt smelling does smelling like an electrical fire count?
Old Jul 24, 2022 | 08:38 PM
Redd86's Avatar
Re: 700r4 issues
The first is true.
Old Jul 24, 2022 | 09:20 PM
vorteciroc's Avatar
Top Answer: 1
Re: 700r4 issues
There are ONLY 3 possible issues:
-The Gear selector is the issue, and is not moving the Gear Selector cable and the Manual Valve in the Valve-Body.
-The Gear Selector Cable is the issue, and is not moving the Manual Valve in the Valve-Body.
-The Valve-Body is the issue, and is not allowing the Manual Valve to move.
Nic Johnson
Sep 15, 2019 10:28 AM
chevydrvr
May 2, 2018 05:54 AM
