86 Iroc-Z Burning Plastic smell
Car: 1986 Yellow Iroc /1987 Blue Iroc
Engine: All 5.0 LB9 TPI
Ok so back in April I had my 700r4 rebuilt, car only has 86k original miles but the tranny started pissing fluid out so I had it rebuilt, before the rebuild the car ran and drove fine with no odors or smells, when I got the car back from the tranny shop I began to smell a burning plastic/ rubbery smell while driving the car for about 10-15 mins, some times it would so strong I was afraid of something catching fire, in my quest to discover the smell I changed out the electric fan which did nothing, I assumed maybe a plastic wire loom was touching something or maybe it was just the smell of the new tranny, anyways one day as I was driving the smell mysteriously went away, I parked the car in a parking lot and when I went to start it again it was completely dead, battery was completely dead and so was the alternator, I changed the alternator and put a new battery in but now the smell is back, i have about 350 miles on the rebuild and really don’t know what else to check, I’m afraid to use the car or go anywhere with it because I don’t want to break down but have no clue where to start to fix this problem
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: 86 Iroc-Z Burning Plastic smell
What you describe sounds like wiring insulation melting due to a short circuit or defective electrical component. A thorough underhood and under-dash visual inspection might give you clue(s).
If not, obtain a factory wiring diagram for your specific car, and then start troubleshooting as per this vid:
Don't drive the car again until you find and correct the problem. To do otherwise may cause the car to burn to the ground.
Engine: 4++,350 & 305 CIs
Almost sounds like a battery cable touching the exhaust or header down by the starter
