700R4 Downshift Question
Old Dec 21, 2022 | 02:30 PM
Procharged GTA's Avatar
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
Hi all, I just built and installed a 700R4 using the Transgo 700 2&3 shift, Corvette Servo, GM High Stall V6 2075 RPM converter, and so on, for a customer. Governor is stock. The application is a 1989 C1500 Chevrolet truck with a mild 350 sbc and B&M 144 Supercharger. Rear gears are 3.42. It shifts great as far as upshifts, but whike in 3rd, running 55-60mph, and going to 100% full throttle, it will downshift back to 2nd gear, even running thats fast. Makes it really scream tight when it does this. TV cable is adjusted tight at WOT, plus we added the Sonaxx Corrector Spring on the cable to increase pressure at part throttle, which seems to work well. What is the cure for the downshifting to 2nd gear at such speed? Thanks!
Brian
Old Dec 23, 2022 | 11:47 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: 700R4 Downshift Question
I would definitly reach out to Dana from ProBuilt. Or VortecIroc
Old Dec 23, 2022 | 07:10 PM
vorteciroc's Avatar
Top Answer: 1
You made Duplicate Threads...
I replied to the other one already.
Procharged GTA
Dec 23, 2022 01:38 AM
DC1992Z28
Nov 9, 2010 02:52 PM
pondriver
Oct 3, 2007 12:09 AM
yaj15
Aug 21, 2007 04:01 PM
