400 Transmission problems
Old Jan 20, 2002 | 08:53 PM
YS's Avatar
YS
I have a 400 transmission in my Chevy. The local transmission shop insalled a B&M shift kit. After the shift kit was installed, the transmission shifts too early with normal driving. The transmission shifts properly under heavier acceleration. I've tried to adjust the modulator valve, but it didn't help. I have also checked the vacuum to the modulator & it's okay. Could the B&M shift kit have caused this problem? I have also read that the double stripe modulator would help. Does anyone have the part # for the double striped modulator valve? Thanks.
Old Jan 20, 2002 | 08:59 PM
Pro Built Automatics's Avatar
What color is your modulator (stripes) now? Which way are you turning the screw to adjust it?
Old Jan 20, 2002 | 09:35 PM
YS's Avatar
YS
400 Trans
Modulator has single red stripe, I have turned it all the way in.
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
camaro71633
Sep 1, 2015 10:24 AM
